Hello friends from Spain
  • Uro-Camper
  • 18. August 2011 um 16:23
  • Uro-Camper
    Spain
    • 31. August 2011 um 18:40
    Sorry
    You can see the video now.
    You can see on the video that the sandwich is very strong
  • Uro-Camper
    Spain
    • 25. September 2011 um 22:36
    Hello. I've long without writing.
    Now I bought a Mitsubishi L200 and begin to prepare.
    First I put Braid wheels. Before I remove the old paint.
    http://www.youtube.com/watch?v=WcP5Mb-mBCo
    Now paint with epoxy primer.
    A bit of sanding after the primer.
    Now paint with metallic paint.
    Then apply micro texture.
    to be continue......
    • 26. September 2011 um 11:58
    Hi Uro.... I followed your project with interest, it looks very professional. The Uro-cover gives an astonishing good looking finish.
    But for me there is a crucial question, which, I guess, will be answered only by long term experience.
    The cabin is built using a mix of different materials, plastic, foam (sandwich) - and wood for the frame. You protect it with a 2 mm layer of Uro-Cover.
    Tha sandwich and the wood will have different extension-grades under the influence of temperature (direct sun in mediterranien regiones up to 80 centigrades and icecold surrounding in alpine climate in winter down to minus 25 centigrade. I fear, that the thin PU-Cover would not stand this during an long period, creating small scratches and thin openings, where water may intrude an start its demolishing work ín the wood.
    Are there any experience or research results about the effects of temperature ob the different materials or have you some information about the elastic capacities of the Uro-Cover? And what will weather erosion (f.e. acid rain and the UV part in the sunlight, snow, ice) do to the cover during longer periods?
  • Uro-Camper
    Spain
    • 26. September 2011 um 13:21
    Hello Thomas.
    Uro-Cover Coating is a 180% elongation. The working temperature is -40 degrees Celsius to 90 degrees.
    Uro-Cover coating can not crack. It is impossible.
    You can see the following work in a sky resort. (Sierra Nevada).
    The surface of the deck in summer and heated to 60/70 degrees at night in winter, cooled to -20, -30 degrees.
    Thanks!!!
  • Uro-Camper
    Spain
    • 26. September 2011 um 16:17
    The next project witch the Misubishi L200
    Saludos
  • jfk
    • 3. Oktober 2011 um 11:26
    i would have said, that the model is a Hilux :)
  • Uro-Camper
    Spain
    • 6. Dezember 2011 um 19:36
    Hello friends.
    It's time to start building our second pop-up.
    Uro-Camper Kubic 2.0.
    Resistance tests on the unit Kubic 1.0 have been very good. It has been tested in very cold and warm sites.
    Here's an 1.0 Kubic video ....
    Externer Inhalt youtu.be
    Now some pictures of the new pop-up KUBIC 2.0
    The vehicle....Mitsubishi L200 extra-cab
    We applied Uro-Coat in the box to prevent rust and improve appearance.
    http://www.youtube.com/watch?v=uBgYjUoLMjU
    to be continued......
  • Uro-Camper
    Spain
    • 9. Dezember 2011 um 09:26
    Design the kubic 2.0...
    http://youtu.be/RlfFk2DJf6Y
  • halber
    • 9. Dezember 2011 um 09:53
    • #29
    alle achtung! wenn google mal ein werbevideo für sketup benötigt - hier ist es schon. hut ab! (vom endprodukt mal ganz zu schweigen)
    lg
    jörg
  • Uro-Camper
    Spain
    • 21. März 2012 um 00:26
    • #30
    Hallo freunde.
    I continue with my work.....
    A greeting.
  • nik100943(inaktiv)
    • 21. März 2012 um 19:39
    • #31
    Hola,
    un gran elogio para la selección de la ENGEL / SAWAFUJI compresor de refrigeración tipo MT-45 F.
    De alta calidad absoluta. Lo mejor de lo mejor.
    Me gusta especialmente la región del Mar Menor y las aguas termales de Alhama de Granada y las cuevas de Purullena / Guadix ... :)
    Saludos cordiales
    Nik
  • Uro-Camper
    Spain
    • 21. März 2012 um 22:25
    • #32
    Zitat von nik100943
    Hola,
    Saludos cordiales
    Nik
    Hola.....pero que bien hablas el español!!!!!
    Tu debes ser de aqui...se te nota en el acento!!! :D:D
    • 22. März 2012 um 06:28
    • #33
    Hola,
    y muchas gracias para el cumplido!!
    Uso "naturalmente" también un programa de traducción del Internet ... :lol:
    Actualmente construyo un camión del tipo Mercedes-Benz 814 con una gran cabina para otros viajes a península y en las islas canarias.
    Mi box de nevera es del tipo WAECO / EUROENGEL CoolFreeze T 162 F y tiene un frigorífico de 162 litros.
    Para que bien bebidas enfriadas sean disponibles siempre bastante ... :P
    Casi me habría comprado ya muchos años antes una casa en Alhama de Granada. Pero. Al fin me tengo para mi proyecto "vida móvil" firmemente, para mis viajes a península ... :D
  • Uro-Camper
    Spain
    • 1. Mai 2012 um 22:39
    • #34
    Hello friends.
    Continuing now teaching my new project.
    and another project ....... Uro-Camper Biwac
    thanks!!!!
    http://cms-5.de/blog.abenteuer…ungsbeschrankt/
  • Uro-Camper
    Spain
    • 5. Juli 2012 um 23:56
    • #35
    Hello friends.
    A new video.
    http://www.youtube.com/embed/4VbHSHfuETY
  • Uro-Camper
    Spain
    • 15. Juli 2012 um 21:00
    • #36
    Hello friends.
    Update with some pictures.
    Best regards!!!
    • 16. Juli 2012 um 09:08
    • #37
    ... wirklich sehr gefällige Kabinchen. Harmonisch zum Basisfahrzeug passend, keine dicken Kantenprofile. Ich bin einmal gespannt, ob Ihr irgendwann auch auf größere Basisfahrzeuge geht!
