  2. Uro-Camper
Beiträge von Uro-Camper
  • Hello friends from Spain
    • Uro-Camper
    • 6. Dezember 2011 um 19:36
    Hello friends.
    It's time to start building our second pop-up.
    Uro-Camper Kubic 2.0.
    Resistance tests on the unit Kubic 1.0 have been very good. It has been tested in very cold and warm sites.
    Here's an 1.0 Kubic video ....
    Externer Inhalt youtu.be
    Now some pictures of the new pop-up KUBIC 2.0
    The vehicle....Mitsubishi L200 extra-cab
    We applied Uro-Coat in the box to prevent rust and improve appearance.
    http://www.youtube.com/watch?v=uBgYjUoLMjU
    to be continued......
    • Uro-Camper
    • 26. September 2011 um 16:17
    The next project witch the Misubishi L200
    Saludos
    • Uro-Camper
    • 26. September 2011 um 13:21
    Hello Thomas.
    Uro-Cover Coating is a 180% elongation. The working temperature is -40 degrees Celsius to 90 degrees.
    Uro-Cover coating can not crack. It is impossible.
    You can see the following work in a sky resort. (Sierra Nevada).
    The surface of the deck in summer and heated to 60/70 degrees at night in winter, cooled to -20, -30 degrees.
    Thanks!!!
    • Uro-Camper
    • 25. September 2011 um 22:36
    Hello. I've long without writing.
    Now I bought a Mitsubishi L200 and begin to prepare.
    First I put Braid wheels. Before I remove the old paint.
    http://www.youtube.com/watch?v=WcP5Mb-mBCo
    Now paint with epoxy primer.
    A bit of sanding after the primer.
    Now paint with metallic paint.
    Then apply micro texture.
    to be continue......
    • Uro-Camper
    • 31. August 2011 um 18:40
    Sorry
    You can see the video now.
    You can see on the video that the sandwich is very strong
    • Uro-Camper
    • 30. August 2011 um 22:40
    Zitat von Rudi
    Hallo Uro-Camper
    Wie stark ist das Sandwich
    Welches Material hat das Sandwich , Holz oder GfK ??
    Translate Google
    How strong is the sandwich
    Which has the sandwich material, wood and fiberglass?
    Qué tan fuerte es el sandwich
    Que tiene el material del emparedado, madera y fibra de vidrio?
    Strong:
    Sandwich: pvc + Foam + pvc
    • Uro-Camper
    • 29. August 2011 um 21:53
    My camper....... :lol::lol:
    • Uro-Camper
    • 29. August 2011 um 21:39
    Questman Hello!
    I will put all the pictures already.
    The applied thickness is 2 mm. The weight of the Uro-Camper Kubic 1.0 is 360 kg with furniture included.
    You can apply least 2 mm thick but offers much resistance.
    I would like you to have the honor to submit to us in the forum http://www.wohnkabinen-magazin.de/
    If all goes well we want to open a manufacturing company.
    Thanks.
    • Uro-Camper
    • 25. August 2011 um 10:03
    more pics..........
    • Uro-Camper
    • 22. August 2011 um 18:52
    Hello.
    Water does not enter into the walls ever. This is impossible.
    After applying the primer applied a plastic spray. It is a polymer that wraps around the cabin. It is a shock resistant plastic. Waterproof.
    In the following video you can see an egg wrapped in this plastic
    You see there is no wood. No joints. Only plastic.
    Now we start with the furniture ..........
    • Uro-Camper
    • 21. August 2011 um 23:40
    When the structure and the walls is finished I give polyester putty to imperfections. Then paint with primer.
    • Uro-Camper
    • 19. August 2011 um 23:56
    • Uro-Camper
    • 19. August 2011 um 23:53
    Thanks for the comments!!!
    The following photographs you will understand be ausencia water can never enter to inside.
    • Uro-Camper
    • 18. August 2011 um 22:59
    http://img830.imageshack.us/img830/5237/imageiif.jpg
    • Uro-Camper
    • 18. August 2011 um 16:23
    Sorry for my bad writing. I use google translator.
    I'm staying here with you to learn more.
    I made our first cell and now we will start the second cell. We set up a company dedicated to this but we need to acquire more knowledge. I would like to know your opinion. We are in Spain.
    Photographs of the construction process.
    Thanks!!!!
  • 2 Mitglieder und 1.095 Besucher
  • pius
  • gfoetz
