Der untere sieht doch aus wie ein "Schädelspalter".
Nene, schon mal rein optisch sieht das aus wie . ![]()
Hello "Uro-Camper" ???,
hear you can see the thread:
http://www.wohnkabinen-magazin.de/de/forum/31-so…ain.html#107428
You should register yourself to anwser questions.
Good luck for your business-plans for building a company.
One of the most common questions will be a price for your cabins.
Do you plan to ad jack supports for the cabin?
Ja und?
Kein Bilder von innen? ![]()
Zitat von jfknur wo bekomm ich das Zeug her?
(Answer for that german Part above: Where do i get this stuff?)
Gibts hier und dort unzählige Threads. ![]()
Suchbegrife:
Ladeflächenbeschichtung
Polyurea
Polyuretan
PU-Beschichtung
Mit PU-Beschichtung meine ich Polyurethan-Beschichtung ala "Rhino-Linings", "Nashornhaut", "Trans Lining",
oder auch das Zeug was "MaTTec" als Protecta-Kote oder
Hercules zum Selbstaufpinseln vertreibt um nur einige Beispiele zu nennen.
Nur selber machen hat nicht die selbe Qualität, wie naß in naß gespritzt.
Aber frag mal Michael und Cordula.
Die können solch einen Polyurethanlack besorgen der ähnliche Eigenschaften hat
Hello Uro-Camper, aka Tribu, ![]()
this is a very interesting project.
But don't let us wait that long for your final pictures.
The final version of the white colored cabin and to cover the interior with the polyurea looks good.
(I've seen the other pics already). ![]()
I think it is a good idea to protect the cabin with that stuff. I've something similiar on my truckbed.
How is the thickness wich is sprayed on the surface of the cabin and the furniture? My question is because of the added weight.
It is a pity that you're that far away from me. Over 2TKm is a bit to far to have a preview of your project.
Will you produce cabins like that as a company?
Or is it only to show the possibilities of your normal business?
You should also show your project on Germanys biggest platform for Truck-Campers:
Their are certainly a lot of people interested on your cabin.
Btw:
Das besprühen mit so einer Polyurea-Beschichtung ähnlich wie Rhino oder Nasornhaut,
ist sicher auch ne gute Alternative für die immer mal gern genommenen Siebdruckplatten für den Kabinen oder Anhängerbau.
Damit erledigt sich auch das "Dichtigkeits-Problem". ![]()
Nennt sich bei den Amis Popup-Camper und gibts unzählige Varianten.
Auch mit "einknöpfbarer" Winterisolierung.
Hängt natürlch von den gwünschten Proportionen ab, was da sinnvoll ist.
Was hast Du gegen diese Dose?
Viele Alternativen wird es nicht geben.
http://www.campingshop-plus.de/antenne_zubeho…,rid,18,kd.html
http://www.campingshop-24.com/printable/wass…dosen/index.php
http://www.carafun.de/technik/elektr…-sat--weiss.php
http://www.skandic-camping.de/Universal-Aussensteckdose
Wenn es eine kleine Lösung sein soll, ohne andere Anschlüsser drin, wirst Du Dir wohl selbst was machen müssen.
Da "Mobile.de" zu ebay gehört, sind die meisten Seiten in den Kleinanzeigen bei Ebay
durch eine automatische Routine generiert worden.
Achte mal drauf. Die meisten Anzeigen findet man auch bei Mobile.de.
Es sei den der Inserent hat ausdrücklich widersprochen.
ZitatIm Fall eines Brandes entsteht bei der Verbrennung von PVC sehr giftiges Clorgas!!
Im eigenen gesundheitlichen Interesse würde ich für den Innenausbau eines Reisemobils nur Werkstoffe verwenden,
die für Innenräume in Kraftfahrzeugen freigegeben sind.
Also ich ziehe es im Brandfall vor, das WoMo zu verlassen.
Andere im WoMo verbauten Einbauten dürften nicht weniger gifitige Gase im Brandfall erzeugen.
Nur mal als kurzes Zitat etwas zu Polyurethan, was ja auch in unseren WoMos, Ausbauten und Klebern enthalten ist:
ZitatDa es sich beim Polyurethan um einen duroplastischen Kunststoff handelt, schmilzt dieser nicht und tropft nicht herab, sodass PUR nicht zur Brandausbreitung beiträgt. Brennendes Polyurethan entwickelt viel Qualm. Durch thermischen Abbau der Polyurethane bilden sich teilweise die Isocyanate zurück. Aufgrund des Stickstoffanteils im Polyurethan entsteht im Brandfall giftige Blausäure, im Zusammenwirken mit dem bei jedem Brand entstehenden Kohlenmonoxid können sehr gefährliche Brandgase entstehen. Zusätzlich kann es durch die im Kunststoff enthaltenen Flammschutzmittel zur Entstehung giftiger Brandgase kommen. Die Brandgase von PUR haben ein großes Geruchsgefährdungspotential.
Das sehr gern genommene "Trocellen" Schaumstoff zum Isolieren, gehört zu den Polyolefinen und hat meiner Meinung nach auch kein "unbedenkliches Brandverhalten".
Obwohl es oft und viel im WoMobau verwendet wird und als "nicht toxisch" gilt.
Polyolefine brennen im gegensatz zu PVC auch außerhalb der Zündflamme weiter.
Bei der Verbrennung können neben den genannten Hauptprodukten auch Alkane, Alkene, Alkohole ( z.Bsp. Methanol ) Aldehyde, ( insbesondere Formaldehyde und Acrolein) sowie aromatische Kohlenwasserstoffe entstehen.
So what?
Moin Moin,
letztes Jahr auf der Abenteuer Allrad war eine Firma aus Miltenberg:
http://www.solidplex.de/
Die hatten beschichtete Platten zum Ausbau dabei, mit einer ultraharten Oberfläche.
Machte mir einen guten und soliden Eindruck.
Evtl. wäre das ja was für Dich.
Die haben Birke und Pappel im Programm.
Die können Dir sicher mal ein Muster schicken.
Zitat von nunmachmalJa, aber ich brauche/möchte das es mir eigene POIs anzeigt.
War jetzt heute noch mal im Fachmarkt!
Siehe da, es gibt diesen Menüpunkt zwar nicht,
aber nach dem berechnen der Route meldet das Teil sich wenn es eine Mautstraße benützt.
Dann kann man den Kopf schütteln.Gruß Nunmachmal
Das kann es doch auch. Man kann die selbst hochladen. ![]()
ZitatMan kann auch selbst Points of Interest oder beliebige Positionen mit ihrer geografischer Länge
und Breite in eine CSV-Datei eintragen und mit dem POI-Loader ins Gerät laden....
...Mit dem POI Loader von Garmin können Sie selbst erstellte oder im Internet erhältliche Sammlungen von Points of Interest,
oder auch TourGuide-Wegpunkte mit verlinkten MP3 Ansagen und Fotos, in Kompatibel Garmin Navigationssystem laden.
Dazu braucht es keinen "Menüpunkt" auf den Navi selbst, da es über eine externe SW funktioniert.
http://www.garminservice.de/downloads/poi-loader/index.php
Ohne eigene SW kann man die folg. POIs über die Garmin HP installieren:
http://www.garminonline.de/extras/poi/
Mit der Garmin SW "Map-Source" lassen sich auch POIs erstellen und direkt zum nüvi hochladen.
Also geht doch alles was Du willst.
BTW:
Klar, auch bei Garmin ist nicht immer "alles Gold was glänzt",
aber der Mehrpreis mancher Garmin-Navis ist meiner Meinung nach durchaus Berechtigt,
wenn mann ein Modell zusammen mit Lifetime Map Update erwirbt.
Auch einzeln erhältlich:
https://buy.garmin.com/shop/shop.do?pID=33380
Frag doch mal direkt bei Schaudt nach:
Was ich bei Deinem "Problem" nicht verstehe,
warum Du offensichtlich nicht wie in der BA beschreiben verfährst.
Dann würde Dir auch Dein "Verbrauch" angezeigt.
Oder hast Du die nicht gelesen?
So kann der Regler nicht ordentlich funktionieren, oder auch richtig Anzeigen.
Schließe den Kram wie unter Punkt 2.2. beschrieben an und fertich. ![]()
Zitat von willyHio
Ich merk hier nix von Adsense?!?
Sagte ich doch, in den Beiträgen zum Glück nicht,
aber oben auf der "Portal-Seite".
Nun die urspr. Abstimmung ist ja von 2004.
Auch wenn ich kein Freund von Tante Googles Schnüffeltools bin,
aber wenn sich der Forums-Betreiber zwischenzeitlich dazu entschließt es einzuführen,
bedarf es doch nicht einer Abstimmung.
Immerhin ist es seine Zeit und sein Geld was wir hier alle nutzen.
Da ist es OK wenn er sowas platziert.
Die hier im Forum eingebundene Werbung ist doch noch absolut harmlos.
Keine Popups, keine dicken Werbebanner auf jeder Beitragseite, keine "Binlayer-Werbung".
Also seit froh, dass es ist wie es ist. ![]()
Btw:
Mag die Foren-SW "ausgenudelt" sein.
Sie funktioniert wenigstens Störungsfrei und ist übersichtlich und kommt ohne den heute üblichen, überflüssigen Schnickschnack aus.
Heutzutage meint jeder, er müsse seinen Scheiß im "Blog-Format" loswerden, am Besten ohne Großschreibung und Satzzeichen,
aber mit nem "Mag-Ich-Facebook-Button".
Ich zumindest habe keinen Bocck darauf, das mein Rechner einen Großteil seiner Leistung mit der Ladezeit blödsinniger Werbung und aufgeblasener Layouts verplemmpert.
Ich bin Froh, dass es hier im WomoBox-Forum noch um das wesentliche geht und man nicht unbedingt dem "Mainstreem" hinterher jagt.
Zum Schluss noch eine Anmerkung. Hier im Thema gehts um Werbung im hiesigen Forum!
Gefällt mir gut der Grundriss.
Ich würde jedoch mal drüber nachdenken,
dass viele "gewichtige" Einbauten hauptsächlich auf der linken Seite zu finden sind.
Da sollte man noch für ein "Gegengewicht" sorgen.
Evtl. sind die Mechanismen der SCA Hubdächer zu gebrauchen?
Wenn Du einerseits mit einem Kanus Tango oder Deseo zufrieden wärst,
dann verstehe ich die Maße für einen Selbstbau-Anhänger nicht ganz.
Mal ehrlich, ich würde einen gebrauchten gut erhaltenen Wohnwagen kaufen
und bei Bedarf nach den pers. Wünschen modifizieren.
Kommt sicherlich biller und Du hast eine vernünftige Basis.
Hier mal ein Beispiel:
http://suchen.mobile.de/fahrzeuge/details.html?id=145903421
Übers Heckfenster lassen sich auch lange Ausrüstungsteile verstauen und Du hast noch finanziellen Speilraum für Umbauten.
